How do I convert PDF to JPG? I googled but could not find any info. Thanks.
Results 1 to 30 of 35
Screen capture?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Hi !
You can try this way :
First you download GPL Ghostscript at http://sourceforge.net/projects/ghostscript/ and install it.
Then you can open your PDF file with a software that allows you to view and convert graphic files like XnView (http://www.xnview.com/) in order to extract the picture as JPG. -
install Foxit Reader
http://www.foxitsoftware.com/pdf/reader_2/down_reader.htm
TOOLS>>>SNAPSHOTI love it when a plan comes together! -
Irfanview can do this as well, with the right plug-ins.
http://www.irfanview.net/
Very versatile image viewer. -
I tried Foxit but the PDF is copyrighted. It would not snapshot.
I use pdf password remover for protected pdfs. Unfortunately I don't know of any free method
And then you can use Acrobat or Foxit mentioned above to take snapshots. -
In Acrobat, click:
"Advanced" > "Export All Images..."
Follow the prompts.
Note that I said Acrobat, not Reader."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
use ghostscript + gsview, open pdf in gsview, choose convert (F), choose jpeg format, choose dpi (eg 300 or 600dpi), in name of file put %04d eg test%04d.jpg - thats all
I didn't know PhotoShop could do that ... I'm in Linux right now and tried GIMP and it read a couple of PDF files I tried. It can read it as one image with each page a layer or you can open each page into it's own window but that took forever.
Doesn't seem to be an easy way to save it all to individual jpg images though without doing it manually which would take forever with very big PDF files.
- John "FulciLives" Coleman
P.S.
GIMP is a freeware image program and is made for Linux and Windows. Maybe MAC as well (don't know).
http://www.gimp.org/"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
PDFs are good for output, but a pain in the ass for source/input.
giveaway of the day has a free program that converts PDF to JPG. http://giveawayoftheday.com/pdf-to-jpg-2/
It's only free today. Also, I have no idea if it's any good or not. -
Set up a print driver that "prints" to an image file.
Googled for "print to tiff", found this free software http://www.landonline.govt.nz/system-support/software-downloads/printer-software-xp.asp on the NZ govt site; so I think it's safe enough. -
Alternatively you can use this plugin in OpenOffice.
Just download it and double click it to install it.
Import your pdf.
(If the layout looks wrong it might be because you do not have the original font of the pdf installed on your computer)
To export all pages automatically I've coded this OpenOffice extention:
http://download.videohelp.com/tin2tin/ConvertToJPG.oxt
Download this and install it by double clicking it.
Tools > Macros > Run Macro (tutorial here)
Select My Macros
Select Slideshow
Select Module1
Select ConvertToJPG
Now all the pages will be exported to a folder .../user/OpenOfficeExport/
And all the files are called something like: dvdslideshowgui-en-2011.05.24-19.56.54_1.jpg
(the reason for the naming is because I coded this for PowerPoint import into DVD slideshow GUI)Last edited by tin2tin; 24th May 2011 at 13:58.
Sigh, now I realise how old this thread is... anyway I hope someone will find this usefull.
I do know that im not supposed to be here for this is a long time ago thread, but i really need a image to pdf converting software, and i am not sure this one is Ok or not, did anyone try this image to pdf conversion component?
Not sure what you trying to achieve but:
http://www.image2pdf.com/
http://online2pdf.com/convert-png2pdf
http://www.verypdf.com/tif2pdf/png-to-pdf.html
http://sourceforge.net/projects/jpg2pdf/
and there is plenty similar programs on internet, there is open office, inkscape, scribus - almost any modern "graphics" software is capable to export pdf
Easy way to convert PDF to Excel?
By Soccerman77 in forum ComputerReplies: 2Last Post: 9th Nov 2010, 19:17 -
VOB convert to jpg
By kevinguyen in forum Video ConversionReplies: 0Last Post: 10th Nov 2009, 15:49 -
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2008, 15:13 -
How do I convert PDF to JPG? Thanks in advance.
By gary11364 in forum ComputerReplies: 1Last Post: 12th Oct 2008, 10:08 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 00:00
