Is there any edit software with a tool for stretching/shrinking audio time, in a graphic/visual way? (click and drag with the mouse instead of entering input values manually)
Results 1 to 10 of 10
Yes, in order to add a new language track to a DVD. The problem is that this new audio comes from a TV recording at 29,970 FPS and has to be synchronized with a DVD video at 23,976 FPS. Using a stretch/shrink tool will causeOriginally Posted by stantheman1976
pitch change. Preserve pitch will slow down speaking pace. Maybe shrinking small parts of the new audio
at a time would work.. -
No, it wont.Originally Posted by dexter30
Vegas should time stretch and pitch shift together, however if it doesn't you can use the non-realtime time stretch plugin to do it.
What you should be doing first, however, is IVTCing the video back to 23.976 fps, then trying to match the video.
You should only have to cut the audio into chunks if there are distinct sections, such as between commercial breaks, that need to be matched. If both versions just ply straight through then you gain very little by slicing your audio up and adjusting in pieces.Read my blog here.
https://forum.videohelp.com/topic355330.html?highlight=ivtc may get you started. It isn't something that I do much - it is primarily an NTSC issue.
Read my blog here.
Stretch mp4?
By yams in forum Video ConversionReplies: 0Last Post: 13th Nov 2010, 20:49 -
Youtube 4:3 stretch
By mitchellrichard in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2010, 04:22 -
can i stretch this video?
By uglijimus in forum Video ConversionReplies: 9Last Post: 9th Oct 2009, 23:02 -
Stretch conversion
By blueleo65 in forum Video ConversionReplies: 15Last Post: 6th Jul 2009, 11:35 -
Help to stretch video
By adhouse13972 in forum Video ConversionReplies: 8Last Post: 7th Jan 2009, 13:06
