Is this possible? I can't play DivX on my little portable dvd player, but would like to be able to watch a tv programme out in the styx.
Each episode is 30mins long. I don't need high quality results, just something watchable on a small screen.
I'm totally new to this and would really appreciate any help at all, even an aggressive push in the right direction.
Yes, although the quality will be so-so. Try using ConvertXtoDVD for an easy way to do this.
Use 352x4810, quality will be fine. Remember to restore overscan if it's missing. ConvertXToDVD does all of this.
352x480, thats often referred too as 1/2 DVD, there is a typo in the above post ,
6 x 30 minutes is only 3 hours. No need to use lower res, just use full 720x480 (or 720x576 for PAL).
You can use a rate of over 3000 bps, which is more than adequate for your average sitcom or drama.
YMMV.
I burnt short samples at various rates to see what it looks like on a TV, as opposed to a monitor.
I actually have a cheap compilation DVD, which has 22 episodes of a sitcom (ca. 22 min each) on one DVD 5. They used 352 x 288 (similar to VCD). Bit blocky on a large screen. Watchable, but I prefer not to squeeze it that much myself. 12 x 25 mins per DVD is my maximum for the ones I author. -
Heh, thanks everyone
. The last 2 forums I asked for technical help in gave me nothing but snide, unhelpful responses. Now I've actually got a resounding positive answer to a question. Thanks again!
As many episodes as possible on one DVD5
By nharikrishna in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2011, 07:56 -
Re: Multiple TV episodes, only decoding the first one
By Franknstein in forum ffmpegX general discussionReplies: 2Last Post: 10th Apr 2008, 23:46 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 15:09 -
Extracting Episodes from a DVD9
By Firewire60 in forum Video ConversionReplies: 0Last Post: 20th Feb 2008, 17:44 -
How do you author many episodes to 1 DVD-R?
By 1980sumthin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 22:49
