I shot an event with an HV-30 set to record 30i SD. I used a stationary tripod mounted Canon SD900 Digital Elph to shoot cut-to footage. It records 640 x 480 at 30 fps in MJPEG. Are there any things that I need to do in order to use these two sources in the same project in Vegas pro 8? The output will be MPEG-2 that will be used to author a DVD.
Evening.
Well, both videos would have to be the same format: Codec, Resolution, and Frame Rate
Audio, you can always mux into the finished video later unless you change the frame rate of either videos.
Interlace vs. Progressive:
MPEG, its ok to mix Interlace and Progressive as long there is provision to modify the flag during encoding. With AVI you have more leaway and can mix either in a final avi project. I do know that in TMPGenc you can modify the flag anywhere inside the encoding project and both I/P can live together. I don't know about Vegas setup however.
-vhelp 4886 -
You can encode them both as interlaced. The only consequence is a little blurring of the chroma channels in the progressive source.
I tried it and it worked fine. There isn't much motion so there isn't any noticeable effect from interlacing the progressive MJPEG video. Most of the footage is from the HV-30. I'm just using the MJPEG footage as a cut-to when the other camera was moving or blocked by someone walking in front of the camera etc. The other thing that I have to deal with is the small black border on each side of the MJPEG footage. 640 X 480 isn't the same size as the DV footage from the HV-30. Is cropping a little off the top and bottom of the MJPEG footage the best way to deal with this?Originally Posted by jagabo
FFmpeg - 60p to 30i
By bunklung in forum Video ConversionReplies: 5Last Post: 3rd Feb 2011, 18:57 -
converting from 30i to 30p with Virtualdub; before or after cutting?
By CFPJer in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 22:17 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
frame rates 24 30 30p 30i 60 60p 60i
By maxtrack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 28th Jul 2007, 16:21
