I just purchase a Toshiba sd 6100 dvd player and made the connection to my tv...great picture and audio but it's black and white, what is wrong? fyi, only other connection is my cable television provider ..those cables going to the tv obviously..no other components.
Using the rca cables that came with the dvd player" component" connection.
Switch the cables around or try substituting different cables. You may have a bad connection. RCA audio cables will also work for short runs.
EDIT: I assume you are using the component out on the player and the component in on the TV? Usually those cables are color coded red, greeen blue. Make sure they are in the proper jacks on both ends. Yellow is usually composite video, red and white is stereo right and left, orange is coaxial audio.
Off chance, but trying to view a PAL video on a NTSC set might also give you B+W, but probably wouldn't work at all with most setups.
DVD Palyer - black and white picture
By majstrydwa in forum DVD & Blu-ray PlayersReplies: 10Last Post: 5th Oct 2010, 11:01 -
Only receive Black & white Picture on TV
By cincsoc442 in forum Video ConversionReplies: 9Last Post: 6th Aug 2008, 10:05 -
Black and white picture on a Panasonic S53 dvd player with Divx video
By gyzer in forum Newbie / General discussionsReplies: 10Last Post: 2nd Apr 2008, 01:10 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 14:00 -
No Sound and black & white picture capturing VHS
By gdkcl in forum Capturing and VCRReplies: 0Last Post: 30th Jun 2007, 14:07
