Which is better: Should I convert X to Y directly? Or X to WAV then to Y?
Does X to WAV equal to decompress?
go directly if possible
sometimes you're stuck with an intermediate file when things don't go as planned -
It should be the same with both, since PCM WAV is lossless
The most common reason for using the WAV intermediate would be to process it in an audio editor. If you are not processing/editing audio, go straight to your final format -
Odds are even if you go "directly" from one format to another it will go through WAV anyway.
Have never noticed any difference in quality between the two methods. Occasionally a video being converted will either not work or give problems with loss of sync, with one of the methods but not the other.
As a rule of thumb, with vbr audio, the recommendatiion is to convert to wav first.
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
Is there a good tool to directly convert DVD into the MP4?
By coody in forum DVD RippingReplies: 4Last Post: 9th Dec 2011, 21:22 -
Is there a way to convert a MKV directly into an ISO file
By netmask56 in forum Video ConversionReplies: 6Last Post: 5th Oct 2009, 12:56 -
convert wav to wv
By pcb in forum AudioReplies: 10Last Post: 12th Apr 2009, 12:08 -
How do I convert .MP3 to .OGG directly?
By Cobra in forum AudioReplies: 11Last Post: 9th Oct 2007, 14:04
