I am having a problem when downloading a movie and trying to link it to dvdfab platnium 4, it wont let me add the file to it on the page where you copy a movie to a dvd? I might be doing it wrong or maybe you can't do it at all. Any suggestions would be great.
ok when using dvd flick, I am quite sure its not just a simple 1,2 and your done I am not sure what I am doing wrong but I cannot take the file and put it on dvd flick to transer vidoe to dvd? I know it sounds as if I am asking you to do it all for me but I am not to computer savoy if ya know what I mean. If you have a simple step process I would really appreciate the help.
Try using ConvertXtoDVD. It is about as simple as you can get with any reliability.
As for the web site you posted - it is full of pirated videos, discussion of which will get this thread locked, and could get you banned.Read my blog here.
thank you I had no idea about that part of discussion, I will remove it I really appreciate the heads up.
Transfering contents from one DVD to another?
By whatever911 in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2012, 12:49 -
DVD Fab 8
By eastert in forum DVD RippingReplies: 7Last Post: 4th Jan 2011, 23:14 -
transfering VHS to DVD
By Chuck Linn in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2011, 11:11 -
DVD Fab HD
By GAR in forum Newbie / General discussionsReplies: 9Last Post: 10th Sep 2010, 19:38 -
DVD Fab Platinum Frequently Fails, But DVD Fab HD Works. Why ?
By MacPCConsultants in forum DVD RippingReplies: 7Last Post: 4th Mar 2008, 04:39
