hey guys, i have 4 yr old camcorder Panasonic DS65. When I had just purchased it, there were no issues with capturing to PC and converting to DVD etc.
Now i used it after a long gap, took some videos, and am unable to capture the videos to PC - using the same PC. Obviusly the PC went through various software changes/upgrades through this time and probably this is causing the problem
I have tried :
Windows Movie Maker - as soon as i click on 'capture from video device - the program crashes
Win DV - it does seem to recognize the camcorder (as Microsoft DV camera and VCR) - however nothing really happens when I click on 'Capture' - moreover there is an error message - 'Can't create CaptureGraphBuilder'
DVIO - as soon as I click on 'Capture Video from Camera' - program crashes
Nero Vision - Failed to initlialize capture device. (even though the program controls the camcorder fine, i.e. plays, rewinds etc.)
Camcorder is connected to PC via firewire (same port that i used 4 yrs ago to capture videos successfully)
I tried Filmerit, repaired whatever it could repair- still no help
Any help would be much appreciated
Am using Win XP SP2
Kev
Results 1 to 10 of 10
you could try installing the free enosoft dv package. it will install their codec in place of the microsoft dvdavi codec which might be missing/corrupt.
Originally Posted by minidv2dvd
(I appreciate the mention!)John Miller -
thanks for the message..
i tried installing the Enosoft DV Decoder, but still the same problem... -
Maybe a problem with Firewire. Does it show up okay in Device Manager?
You can also try to uninstall the device, it will come back on a restart.
Also a good point to start with: firewall. Do you use a 3rd party Firewall?
A few treat Firewire as a Network, sometimes blocking access.
Good luck! -
Try reregistering the qdv.dll and quartz.dll components of DirectX.
Start>Run> then type the below one after the other:-
regsvr32 /s qdv.dll
regsvr32 /s quartz.dll
Reboot the PC and see if you can capture."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Originally Posted by JohnnyMalaria
at one point i had your enosoft dv codec as default but had to change it out in the registry .dvsd key when it "expired", back to the ms one. i guess i had installed the wrong enosoft program?
@kev35 - how about starting the playback on the cam and then pressing capture in winDV? a new firewire cable might be another thing to test. -
hey guys
thanks so much for all the help
tried all the mentioned suggestions - still the same problem
(i tried the camera and firewire cable on a friend's laptop, where it all works perfect) - so definitely a software issue with my PC
tks
Kev -
Our software has a diagnostics feature that you can use to send us detailed info such as which filters you have, any errors that are reported when trying to capture etc. If you wish to do so, click the large Configure... button and then Create Diagnostics Report and follow the instructions. The diagnostics aren't limited to our software - the info is system wide. I'll take a look and see if anything is missing/wrong.
John Miller -
thanks a lot John
will do this asap, and post the report on the thread
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Can you capture from a MiniDVD camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Sep 2008, 21:52 -
Capture from DV Camcorder
By quxote in forum CapturingReplies: 2Last Post: 16th Jun 2008, 22:41 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum CapturingReplies: 11Last Post: 5th Oct 2007, 04:31 -
Necessary to capture from a dvd camcorder?
By bobogs in forum CapturingReplies: 4Last Post: 17th Jul 2007, 03:13
