Hello. I'm trying to get some copy come 8mm tapes to NTSC DVD-Video and since I'm not used to do that I'm getting this difficult.
As now, I used VirtualDub to have all the videos in AVI files. Video codec is DivX 6.8, 4058 kbps, 29.70 fps, and uncompressed audio (44.1 kbps, 16-bit, Mono). Maybe overkill, but the quality isn't very good so I don't want to lose even more due to processing.
I'm using FAVC to... authoring(? this is called to make a DVD Player compatible disc, right?) the videos, following this guide. When clicking in the "Generate Button" I get this message:
FAVC is unable to process the following files:
D:\video\capture\primera-presentacion-13-08-2005-NTSC.avi
D:\video\capture\presentacion-30-08-2005-NTSC.avi
Generally this problem occurs when the correct version of Avisynth is not installed (v2.56a or Greater),
or the corresponding codec is not installed.
Alternative approaches include creating an Avisynth script yourself and opening it in FAVC,
or frameserving from VirtualDub to FAVC.
I even got this message trying with a file with uncompressed video and uncompressed audio, and installing the last Avisynth (AVS 2.5.8 RC4 [080831] downloaded from Sourceforge) restarting later. I have .NET 2 installed in my PC.
What can I do?
In FAVC's working folder there will be the avisynth scripts that it created. Try opening these in Virtualdub, and report back any error message you receive.
Read my blog here.
Having trouble getting mkv to mpeg2 with FAVC
By Onceler2 in forum Video ConversionReplies: 1Last Post: 31st Jul 2011, 17:14 -
Favc
By sportflyer in forum Video ConversionReplies: 8Last Post: 19th Feb 2010, 19:20 -
Having trouble downloading FAVC
By chohmann in forum Newbie / General discussionsReplies: 10Last Post: 4th Apr 2009, 02:09 -
help using FAVC
By eao1 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2008, 18:41 -
Having Trouble with FAVC
By littlebrittle in forum Authoring (DVD)Replies: 3Last Post: 25th Sep 2007, 03:11
