in Premiere, after I've edited the .M2V from a DVD PAL, when exporting the movie as DV PAL, how can I find out what interlacing mode should I use, betwen "upper field first" and "lower field first" ?
AnonymousGuest
Agree. Set edit project and encoder to same as source. Avoid conversion. Most players don't care if original is TFF or BFF. They just want to know which.
Conversion is only needed for mixed TFF or BFF sources.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 12:27 -
PAL to NTSC -- Upper or Lower field first?
By hurricane1951 in forum EditingReplies: 2Last Post: 1st Aug 2008, 06:39 -
DV Lower Field First - can be rendered as progressive scan ?
By tarrickb in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 08:19 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19
