  1. Hi,
    Does anyone know how to get the mpeg movie out of a vob-file with the audio so i don't have to reencode the movie?? there has to be a fast way to extract the vob and import the video and audio in an authoring program.
    Wich program should i use for authoring and how can i extract the video????
    80% of the dvd movies are under 4,3 GB if you only count the actual movie so why bother ripping?? right???
    greetings from Belgium
    Sis3970
  2. :P Hi , there are some commercial program's i have been told. But i don't know wich one's. And i have the same question. Please help us!!!
  3. you can use stream processing in smartripper which will allow you to copy the movie file (m2v file) and the audio file to your hard drive. You can then use spruceup to author. It accepts ac3 but not dts
