In authoring an MPEG-2 file encoded with "AC3 Stereo," DVDStyler has seemingly re-encoded the audio with "AC3 5.1." What sort of consequences does this have in burning and playback?
This change was revealed in DVD Shrink, which shows the original "AC3 Stereo-ch Unspecified" audio maintained under "Compression Settings" when I used a different authoring application on that same MPEG-2 file. Why would DVDStyler appear to change the audio compression setting when that other authoring application left it alone?
Lastly, what would be the consequences if I unchecked the box next to "AC3 5.1-ch Unspecified" (or "AC3 Stereo-ch Unspecified" for that matter) under the "Compression Settings" in DVD Shrink? Thank you.
DVDStyler may assume you are stupid, and does what it wants to do. Or it may only know 5.1 and not 2.0, due to bad programming.
Unchecking a box in DVD Shrink removes the audio from the disc.Want my help? Ask here! (not via PM!)
On the fly software AC3 encoding
By djdynamite123 in forum AudioReplies: 12Last Post: 24th Jul 2011, 16:35 -
DVDstyler error
By Anh Mike in forum Authoring (DVD)Replies: 0Last Post: 16th Oct 2008, 17:39 -
Using ffmpeg to mux an arbitrary number of streams from multiple files
By punmaster in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 00:14 -
No Audio when encoding with AC3
By Stankia in forum AudioReplies: 2Last Post: 25th Apr 2008, 18:44 -
AC3 dialnorm encoding
By RobinReumers in forum ffmpegX general discussionReplies: 0Last Post: 6th Jun 2007, 09:35
