Im pulling my hair out over here! Ok i downloaded some movies off the net, they play fine on my computer, they were originally avi. i used TMPGEnc cpnverted them to Mpeg watched them again look great. Ok tried burning to VCD with Nero latest version, tried first onto a CD-R then read nope wont work ok no prob went out and bought Memorex High Speed CD-RW and Memorex 1x-4x and Digital REsource 16x CD-RW
the Digital resource ones i can burn to using Nero and it will play on my computer but not in my stand alone DVD player, so i do some reading adn find out for my DVD player(Sony DVP-S360) that the Memorex CD-RW is best to i throw one of those bad boys in the burner fire up Nero and select all my setting and i get this error no matter what speed i try to burn at
SCSI Target Error
Sony CD-RW CRX140E
Could not perform start of Disc at once(i tried Track at once also)
Burn failed at 4x(600k/b) Failed no matter what speed i tried
It gives me that with both Memorex brand CD-RW i tried but works with the cheesomatic CD-RW's Is this a burner problem or software?
I also tried VCDeasy and it comes up with a ASPI error for drivers is my burner too old? its almost 2 years old bought it in the Dell i bought. If it is out of date could you please recommend a good replacement one. Thank IMMENSELY in advance for any and all help!
Results 1 to 1 of 1
