Hi all.
I have Womble's Mpeg Video Wizard v4.04.
The four windows of the program (Project area, Input screen, Output screen and the Timeline) are all docked / locked together. I would like to undock them so that I can change the size of any one of them independently.
Can anyone tell me how? Sometime back I used to do that but have forgotten now.
Thanks for helping out. Regards.
Amer
In toolbar there's 'Component Layout' icon (left to 'help') where you can select maximized/minimized layout types for different tasks. The only resizable version doesn't allow for moving the components to other position, but you can resize them (e.g. monitors) over the adjacent tabs.
Thank you so much, friend. That was great help fpr me. Your advice has been extremely useful.
Regards.
Amer -
I'm sure by now you found the "unbind" cmd in the Component Layout tab.
You can move and resize all windows. Except TimeLine window only sizes Hor. no Vert. This is ver.4.0.4.108
good luck, GeorgeThe Second Amendment:
AMERICA'S ORIGINAL
HOMELAND SECURITY
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
By newshoes in forum Software PlayingReplies: 10Last Post: 20th Mar 2008, 11:22 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52 -
How to use Mpeg Video Wizard
By windranger in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 09:24
