Hi
I am looking for a SWF standalone desktop player. i have used aero and do not like it much.
I downloaded the flv player from here and its v quick to launch and excellent player. Is
there not any free swf player around ?
Since both are flash, I wonder why any flv player does not play swf files ? ?
flv is just video and swf(shockwave flash) can contain both video and flash content so it requires a different decoder.
There's a number of them.
The three I use are:
Media Player Classic
IrfanView (though its Flash support may be a little dated)
...and versions of the Macromedia executable Flash player I extracted from stand-alone Flash .exes (which aren't as common these days, I guess.)If cameras add ten pounds, why would people want to eat them? -
Media Player Classic can play SWFs. Try opening one in MPC.
I don't think it has an easy, direct way of changing the brightness and contrast, no. There are some effects you can use under Play > Shaders (and you can add to those choices with View > Shader Editor, but I certainly don't know how to do anything with it
), but that's mostly about it. I think MPC depends more on the system and decoder settings for that.
I like using MPC to play SWF files, though, because it has no problem letting you scale them to full-screen.
Is there any media player that plays FLV or SWF files form Youtube?
By peggypwr1 in forum Newbie / General discussionsReplies: 14Last Post: 13th Nov 2015, 00:55 -
Creating a slideshow as a standalone .swf file
By marioval in forum Newbie / General discussionsReplies: 8Last Post: 2nd Sep 2009, 11:36 -
about desktop FLV player for Windows
By siluet in forum Newbie / General discussionsReplies: 16Last Post: 31st Oct 2008, 16:34 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 23:15 -
avi to swf or mov to swf
By halteach in forum ffmpegX general discussionReplies: 2Last Post: 2nd Dec 2007, 06:18
