Hi ,
I have an LG RH 399 DVD recorder and have been struggling to record contents that are on the Hard disk drive to a DVD.
Furthermore when I connect my Panasonic Mini DV Camera via a firewire cable I am cannot see the picture on my TV nor am able to record direct to DVD.
Please help.
Chris
TO record from DV to DVD via Firewire make sure you have the proper line-input on the unit selected. You'll know you have the right input if you see the picture on the connected TV. If in doubt, press zero on your remote (if any luck it will go to the dv input, if it doesn't use the ch down . If you're having problems recording from HDD>DVD check with the manufacture for compatible recordable disc versions (2x 4x) etc.
cheers
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 15:28 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
What format for VHS to HDD to TV? Playing off a HDD instead of DVD?
By Rudyard in forum Video ConversionReplies: 10Last Post: 6th Aug 2009, 20:46 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
PC HDD Driver for Panasonic DVD Recorder HDD
By SG-01 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 30th Aug 2007, 04:54
