I'm getting tired of wondering (inside my head) with what went wrong to my USB-2 speed.
For some unknown reason, my front ports went 1.1 on me and the only way I can get the 2.0 speed is to connect from the back of the unit. The mobo comes with 4 ports .. 2 in the front and 2 in the back.
I would like to request the aid of any USB/MOBO gurus to help me figure out what caused this and how to restore it back to health, but without having to reinstall windows xp again.
My rig:
** April 21, 2007 Sat -- new purchase
** MOBO: ECS GeforceE6100SM-M w/ 1gig DDR RAM
** CPU: AMD 64 X2 3600+
Thank you,
-vhelp 4884
have you checked the bios to make sure "enhanced" usb is enabled? the next step would be to reload the nvidia motherboard drivers. maybe then try looking in the hardware device manager and see if there are a couple "enhanced" host controllers listed. is this vista or xp? there are some updates for nvidia usb chips, but mostly vista with 2gb or more ram seems to be the normal problem.
help finding player. USB and play from home network
By billkater in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Dec 2010, 22:39 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
I lost audio in source and preview in all editing programs, how to fix??
By RogerTango in forum EditingReplies: 2Last Post: 9th Nov 2009, 21:43 -
Desperately Need Help Finding a Good DVD Player With a Usb Port That Has...
By thewonderer in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Apr 2009, 17:07 -
Finding out write speed
By BrokenOne in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st May 2008, 02:40
