Hi,
I recently bought an LG home theater, model number HT302SD. The manual says that it supports VobSub subtitle format. I need this specific format because my subtitles are all in an "unsupported character set". So, the only way to show them is to use bitmap-based subtitles, which is the VobSub format.
The problem is that I couldn't get the VobSub subtitles to show while palying DivX files. The following descripes exactly what I did:
1- I named the DivX file as: m.avi
2- I named the 2 subtitles files as: m.sub and m.idx
3- I put the three files in the same folder on a USB flash memory
4- I inserted the flash memory in the LG player which showed me the list on these files on the TV.
5- I ran the DivX file.
6- I tried to make the subtitles appear (by pressing the subtitles button on the remote control), but the LG player could not detect them.
Any idea on how to fix this probelm??
Thanks a lot in advance.
AAC 5.1 playback on home theater receiver problem
By Phat J in forum Media Center PC / MediaCentersReplies: 5Last Post: 30th Jul 2013, 03:45 -
How can i make Media Player Classic Home Cinema show DVB subtitles?
By fk in forum Software PlayingReplies: 0Last Post: 25th Jan 2011, 05:59 -
Problem With Phillips HTS 5610 Home Theater System
By Gareth2701 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Dec 2009, 02:08 -
LG home theater, speakers giving problem.
By sajjadbaqir in forum Media Center PC / MediaCentersReplies: 7Last Post: 5th Sep 2008, 19:01 -
plz help my dvd audio is always cracking in my home theater system.
By rex2745 in forum Newbie / General discussionsReplies: 11Last Post: 24th Jul 2007, 06:10
