I borrowed a DVD Movie from my friend and the movie's length is longer than 120 min. Why?
Isn't it supposed to be shorter than 120 min for a dvd??
See the column WHAT IS > DVD to the left on this site. Depending on bitrate and resolution, you can go up to 5 or 6 hours on a DVD-5 and 9 hours on DVD-9. Of course, the more you compress the video to cram onto the disc, the crappier the image gets.
file size = bitrate * running time
You can put as long a running time you want on a DVD, just use low enough a bitrate. Of course, the lower the bitrate the lower the quality. -
He must be used to seeing the "120min" that is stamped on most dvdr's 8)
hzgg2 is not alone if indeed he "is used to seeing 120mins stamped on most DVDRs." I have to explain to lots of people I encounter with DVD recorders how and why the 120mins on the label is NOT set in stone, as is how "it can be 240mins if set to LP", etc. DVDR manufacturers should stop putting these labels; stating it's 4.7GB (or 8.5) is enough. How long the recording will max out at what bitrate depends on the recorder which isn't the same for all.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
What is the 120 minutes DVD length based on ?
By davexnet in forum Newbie / General discussionsReplies: 7Last Post: 9th May 2010, 22:11 -
How do I upload a video to youtube that's longer than 10 min? (besides.....
By Spritemoney in forum Video ConversionReplies: 3Last Post: 27th Dec 2007, 12:54 -
LG DVD-R 4.7GB/ 120 mins. 1-8X DVD Disc with 2:28.52 movie
By Gerald Sr. in forum Authoring (DVD)Replies: 4Last Post: 12th Nov 2007, 17:09 -
Longer length mini dv tapes?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 11th Nov 2007, 05:48 -
burn 120 minutes movie in 1 CD?
By hackerzlab in forum Newbie / General discussionsReplies: 18Last Post: 9th May 2007, 11:16
