I searched the internet and also this site but I haven't been able to find solutions to what I'm trying to do.
I need to create a multiple language dvd, preferable using Gui for DVDAuthor. What I'm trying to do is to create a DVD that will give the option to go to different language menus on the startup menu. Such as, the options may be English or Spanish on the opening menu screen. When the user clicks on the language they want, it will go to that language's submenu(s).
That part is easy enough. However, the tricky part is using only one video file but different audio files to go along with it. Such as, if you click on Spanish on the opening menu, it goes to the Spanish language submenu where all of the options are in Spanish. When they click on the video to view, it automatically plays the Spanish audio track.
If they were to choose the English option, it would go to the English submenu(s) where all of the options are in English and the video will automatically play the English audio track.
I've tried to do this but have had no luck getting it to jump to the correct audio track with the one video file.
I have found that even when entering jump commands properly, not all DVD players will respond -- especially older units. I've not yet experimented with Gui for DVDAuthor using Muxman as the muxing engine, but you might have better luck with that. Or else, wait until Borax responds to your post.
Use a register (GPRMX or just gX for dvdauthor) to hold the language info. Then check this register in the pre command of the video to set the correct audio track.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
It can be done with any authoring tool which allows access to GPRMs, SPRMs and scripting. Correct. And GfD allows that. But you need a good plan (maybe even something like a flow chart on a piece of paper) and some knowledge about the VM language (and i.e. their limits...)
GUI for dvdauthor:
I'm afraid I don't have any experience using a register such as GPRMX to hold the language info as was suggested. Is there a guide that describes how to do it?
Multiple Language Conversion mov or mp4
By Tseng61 in forum Video ConversionReplies: 1Last Post: 19th Sep 2010, 03:57 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 14:06 -
Multiple language soundtracks on Wombler
By eliserh in forum AudioReplies: 0Last Post: 15th May 2010, 04:20 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
multiple language tracks in iTunes
By Patrick_H in forum DVD RippingReplies: 0Last Post: 15th Feb 2008, 11:12
