I was trying to create an mpg from a vob file. I would click start, get the first step that takes 2 secs, and then click start again. It then zips straight through the file in 1 sec and creates a size 0 mpg file. It only does this on this vob file.
I have selected the video portion of the vob file. Used DVDfab Plat 4 to rip the DVD. Other files from other rips work fine.
sometimes it gets picky. did you rip it movie only with just 1 audio track? if not give it a try.
Yep, did that already. No joy. Couldn't rip just one audio track either. After we analyzed what was happening we think the DVD is screwed up somehow. Another DVD from the same set has no problems.Originally Posted by Almost Human
The program only allows you to select a folder - and it won't output across volumes.Originally Posted by Ai Haibara
But yes, I had a different folder for the output selected anyway. My net minion thinks it may be the DVD itself that is screwed up.Originally Posted by sambat
MPEG won't import after converting using VOB2MPG
By olweiser in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 12:44 -
Registration won't finish (vob2mpg pro)
By kfealz in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2010, 07:13 -
Extract Subtitle Stream from MPG (Used VOB2MPG to create file)
By secretsubscriber in forum SubtitleReplies: 2Last Post: 4th Jun 2009, 14:02 -
VOB2MPG won't start up
By lesonja in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 2nd Jan 2008, 12:24 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 20:04
