Results 1 to 11 of 11
  1. Member X_Splinter's Avatar
    Jan 2007
    Portugal
    Hi there.
    I have a problem that never happend to me before.
    I install Gordian Knot and cant rip nothing because the virtualdubmod.exe doesnt work, i even downloaded from the their site and still not work, simply nothing happens and i click on it.
    I can run VirtualDub but i cant run VirtualDubMod
    There must be something missing in my computor, i am using Windows XP SPK3.
    Any ideas... please
    Sep 2008
    Hungary
    Hi,
    Same issue on my side also. XP SP3 too....
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    reinstall it into a new directory. That should help. Make sure you have the latest version of vdub that you are trying to use also.
  4. Member X_Splinter's Avatar
    Jan 2007
    Portugal
    I downloaded vdubmod from its website, i extract it and still nothing happens when i double click it.
    It was to be something concerning the service pack 3
  5. I'm have XP SP3 and not have problems with VDM and VD.
  6. Member X_Splinter's Avatar
    Jan 2007
    Portugal
    Did you installed any additional NetFramework or something??? VD works fine but VDM doesnt.
    In my other computors work fine, and worked with this computor when i had Vista installed. Now i Have Xp SP3 and doesnt work... Danm....
  7. Originally Posted by X_Splinter
    ...Did you installed any additional NetFramework or something??? ...
    Yes. .NET Framework 2.0 and 3.5 (because it's required by some apps - example meGUi and StaxRip).
    I'm check VDM 1.5.10.2 (b2540 and b2542) also VDM 1.6.0 Surround (b2560).
    Hmm... maybe try add to registry this:
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Freeware\VirtualDubMod]
    "VirtualDub"=dword:00000001
    "SeenWelcome"=dword:00000001
    "SeenMatroskaDeprecated 1.5.10.2"=dword:00000001
    Sep 2008
    Hungary
    I've just tried all tips you gave:
    - Reinstall to a new directory
    - Registry tip
    - Install .net 1.1 language pack
    - Install .net 2.0
    but none of these helped. And as I remember VDM worked fine on XP SP2 with .net 1.1 only.
    Any more tips I could try?
    Nandi
    Sep 2008
    Hungary
    I have uninstalled all gordian knot related sw's, and installed the gk codec pack then the rip pack, and virtualdubmod is working fine... very interesting...
  10. Member X_Splinter's Avatar
    Jan 2007
    Portugal
    Really? So i am gonna try to do that...
  11. Member X_Splinter's Avatar
    Jan 2007
    Portugal
    I found the BUG
    Its the FFDSHOW, this 2008 version sucks... I simply unistall it and voilá VDM works.
    Someone should report this bug to them.
    Anyway thank you guys for the tips
