I got some rmvb files with Bit rate: 592 Kbps to convert to dvd.
I am using TMPGEnc 4.0 XPress for convertion with DVD5.
I would like to know whether I should remain the bit rate or increase it in order to get best quality and fully use the space of DVD5?
Can suggest how many files I should include inside one DVD5?
Increase. 2 to 4 hours per single laer DVD -- depending on the frame size and quality of the source.
You should definitely use a higher bit rate to convert Real Media to DVD. Real Media is an awful codec - very lossy. You will need a high bit rate to make the conversion look as good as possible.
You have to be the judge of how many files to include and what bit rate to use. As a general rule I don't make DVDs with a bit rate below 4000 Kbps because I feel that the quality suffers too much. Such a bit rate will give your roughly 2 hours and 25 minutes of video on a DVD-5. -
Each file is 44 min 10s. So I convert 2 files together? Each got 66700 frames.
Does TMPGEnc 4.0 Xpress support constant quality encoding like TMPGEnc Plus? If so, try encoding one of your episodes in constant quality mode (if it's like the older TMPGEnc try a quality of 80 or so) and see how big the file turns out. That will give you an idea how many episodes you can put on a DVD.
Best libx264 -vpre preset to use/is there a way to convert bit rate ONLY?
By ninethirty in forum Video ConversionReplies: 6Last Post: 16th Feb 2011, 11:11 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
The Best Bit Rate For DVD's...
By GRAMOPHONE in forum Authoring (DVD)Replies: 2Last Post: 23rd Apr 2008, 23:37 -
Is low bit rate mpeg2 (1200kbps) compatible with all DVD players?
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2008, 08:49 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48
