Hi, I have personal mpeg footages that are 300 MB in filesize. I would like to convert these into a smaller file size for future use (watch them later on via dailymotion or youtube). I need to convert them into 150 mb or less. What is the best tool out there?
Please note that each conversion is lossy, so you will lose quality. If you try to upload your files to YouTube or similar sites, they may yet re-encode your videos again to comply with their standards. And if one day you want to re-encode your re-encoded videos to DVD or BluRay, the final result is probably not going to be very good at all. You can get the size you want, just be sure before you start that you are willing to accept any quality losses to get the desire size.
Thank you, Baldrick and jman98. I won't worry about quality loss since I won't be overwriting / deleting the original. I just needed to resize / convert some of it to upload online so I can watch them when I am away from home. Since most of the video sites I know only allow very limited size and running time of clips for upload. Unless there is one that I don't know of....
converting HD mov to smaller size
By bolter in forum ffmpegX general discussionReplies: 1Last Post: 13th Dec 2011, 12:47 -
Converting videos -> smaller file size
By karib in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 14:31 -
Can I get VOB to smaller file size with no loss of quality?
By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 13:11 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 06:14 -
Smaller file size after Video Capture (help)
By convoy71 in forum Capturing and VCRReplies: 4Last Post: 4th Apr 2009, 17:05
