Results 1 to 10 of 10
    Nov 2005
    Belgium
    Hi,
    It's bin a while but i'm back . Maybe someone can help me with this problem.
    I'm trying to encode an .avi file to DVD, but there is no .mpv appearing.
    Steps:
    Summary: AVI to DVD mpeg2enc
    Filters: VOB subtitles, Load sub .srt
    Options: no vcd scan, letterbox, Decode with mplayer, Altivec, Bicubic
    encode.
    Process info;
    Encoding started on Fri Sep 5 11:19:29 CEST 2008
    /Users/admin/Desktop/49/49.avi.ff/
    /Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 207: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file
    -f 5 -b 3200 -q 3 -B 260 -V 230 -a 3
    -F 4
    FIXME:Hardenabling SSE and SSE2 without detection
    MPlayer dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    CPU: Intel Pentium III Katmai/Pentium III Xeon Tanner (Family: 6, Stepping: 6)
    CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    get_path('codecs.conf') -> '/Users/admin/.mplayer/codecs.conf'
    Reading /Users/admin/.mplayer/codecs.conf: Can't open '/Users/admin/.mplayer/codecs.conf': No such file or directory
    Reading /usr/local/etc/mplayer/codecs.conf: Can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
    Using built-in default codecs.conf.
    CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '-osdlevel' '0' '/Users/admin/Desktop/49/49.avi' '-aid' '1' '-sid' '1'
    get_path('font/font.desc') -> '/Users/admin/.mplayer/font/font.desc'
    font: can't open file: /Users/admin/.mplayer/font/font.desc
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay
    Using Darwin accurate timing
    Terminal type `unknown' is not defined.
    get_path('input.conf') -> '/Users/admin/.mplayer/input.conf'
    Can't open input config file /Users/admin/.mplayer/input.conf: No such file or directory
    Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
    Falling back on default (hardcoded) input config
    get_path('49.avi.conf') -> '/Users/admin/.mplayer/49.avi.conf'
    Playing /Users/admin/Desktop/49/49.avi.
    get_path('sub/') -> '/Users/admin/.mplayer/sub/'
    [file] File size is 729484786 bytes
    STREAM: [file] /Users/admin/Desktop/49/49.avi
    STREAM: Description: File
    STREAM: Author: Albeu
    STREAM: Comment: based on the code from ??? (probably Arpi)
    AVI file format detected.
    list_end=0x146
    ======= AVI Header =======
    us/frame: 40000 (fps=25.000)
    max bytes/sec: 650000
    padding: 0
    MainAVIHeader.dwFlags: (2064) HAS_INDEX TRUST_CKTYPE
    frames total: 164529 initial: 0
    streams: 2
    Suggested BufferSize: 864000
    Size: 720 x 400
    list_end=0xD4
    ==> Found video stream: 0
    ====== STREAM Header =====
    Type: vids FCC: xvid (64697678)
    Flags: 0
    Priority: 0 Language: 0
    InitialFrames: 0
    Rate: 1000000/40000 = 25.000
    Start: 0 Len: 164529
    Suggested BufferSize: 1152000
    Quality -1
    Sample size: 0
    Found 'bih', 40 bytes of 40
    ======= VIDEO Format ======
    biSize 40
    biWidth 720
    biHeight 400
    biPlanes 1
    biBitCount 24
    biCompression 1145656920='XVID'
    biSizeImage 864000
    Regenerating keyframe table for MPEG4 video
    list_end=0x146
    ==> Found audio stream: 1
    Type: auds FCC: (0)
    Flags: 0
    InitialFrames: 0
    Rate: 20000/1 = 20000.000
    Start: 0 Len: 274191
    Suggested BufferSize: 0
    Quality -1
    Sample size: 1
    Found 'wf', 30 bytes of 18
    ======= WAVE Format =======
    Format Tag: 85 (0x55)
    Channels: 2
    Samplerate: 48000
    avg byte/sec: 20000
    Block align: 1
    bits/sample: 0
    cbSize: 12
    mp3.wID=1
    mp3.fdwFlags=0x2
    mp3.nBlockSize=8640
    mp3.nFramesPerBlock=1
    mp3.nCodecDelay=1393
    list_end=0x2B0FF1EA
    Found movie at 0x2800 - 0x2B0FF1EA
    Reading INDEX block, 438720 chunks for 164529 frames (fpos=722465266)
    AVI index offset: 0x27FC (movi=0x2800 idx0=0x4 idx1=0xC46)
    looks like this file was encoded with (divx4/(old)xvid/opendivx) -> forcing low_delay flag
    [mpeg4 @ 0x7f4b2c]looks like this file was encoded with (divx4/(old)xvid/opendivx) -> forcing low_delay flag
    INFO: [yuvscaler] SVCD output format requested in PAL/SECAM norm
    INFO: [yuvscaler] input: frame size: 720x400 pixels (432000 bytes)
    INFO: [yuvscaler] input: frame rate: 25/1 fps (~25.000000)
    INFO: [yuvscaler] input: interlace: none/progressive
    ideo ID = 0
    Auto-selected AVI audio ID = 1
    AVI: Searching for audio stream (id:1)
    XXX initial v_pts=0.040 a_pos=0 (0.000)
    AVI video size=587114367 (164529) audio size=131611678 (131611678)
    VIDEO: [XVID] 720x400 24bpp 25.000 fps 713.7 kbps (87.1 kbyte/s)
    [V] filefmt:3 fourcc:0x44495658 size:720x400 fps:25.00 ftime:=0.0400
    SUB: Detected subtitle file format: subviewer
    SUB: Read 767 subtitles.
    tio: ?
    INFO: [yuvscaler] from 720x400, take 720x400+0+0, NOT_INTERLACED/PROGRESSIVE
    INFO: [yuvscaler] scale to 720x300, 720x400 being displayed, NOT_INTERLACED/PROGRESSIVE
    INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
    INFO: [yuvscaler] without line switching
    INFO: [yuvscaler] without time forwarding
    INFO: [yuvscaler] Without luminance correction
    INFO: [yuvscaler] Without chrominance correction
    INFO: [yuvscaler] black lines: 50 above and 50 under
    9.srt
    Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
    dec_audio: Allocating 4608 + 65536 = 70144 bytes for output buffer.
    mp3lib: using generic C decore!
    MP3lib: init layer2&3 finished, tables done
    MPEG 1.0, Layer III, 48000 Hz 160 kbit Joint-Stereo, BPF: 480
    Channels: 2, copyright: No, original: Yes, CRC: No, emphasis: 0
    AUDIO: 48000 Hz, 2 ch, s16le, 160.0 kbit/10.42% (ratio: 20000->192000)
    ack columns: 0 left and 0 right
    INFO: [yuvscaler] frame rate: 25.000 fps
    INFO: [yuvscaler] Scaling ratio for width is 1 to 1
    INFO: [yuvscaler] and is 4 to 3 for height
    INFO: [yuvscaler] Specific downscaling routing number 7
    MPlayer interrupted by signal 13 in module: flip_page
    - MPlayer crashed. This shouldn't happen.
    It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
    gcc version. If you think it's MPlayer's fault, please read
    mp3lib (mp3lib MPEG layer-2, layer-3)
    Using (default) progressive frame mode.============================================= =============================
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    INFO: libavcodec init OK!
    Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
    the instructions there. We can't and
    won't help unless you provide this information when reporting a possible bug.
    INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
    INFO: format = 0x1, audio length = 65536 bytes
    INFO: slots/frame = 672
    INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
    INFO: System is big endian
    0ch/??...
    [libaf] Adding filter dummy
    [dummy] Was reinitialized: 48000Hz/2ch/s16le
    [AO PCM] File: audiodump.wav (WAVE)
    PCM: Samplerate: 48000Hz Channels: Stereo Format s16le
    [AO PCM] Info: Faster dumping is achieved with -vc null -vo null
    [AO PCM] Info: To write WAVE files use -ao pcm:waveheader (default).
    AO: [pcm] 48000Hz 2ch s16le (2 bytes per sample)
    AO: Description: RAW PCM/WAVE file writer audio output
    AO: Author: Atmosfear
    Building audio filter chain for 48000Hz/2ch/s16le -> 48000Hz/2ch/s16le...
    Starting playback...
    [ffmpeg] aspect_ratio: 1.800000
    VDec: vo config request - 720 x 400 (preferred colorspace: Planar YV12)
    Trying filter chain: vo
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.80:1 - prescaling to correct movie aspect.
    VO Config (720x400->720x400,flags=0,'MPlayer',0x32315659)
    VO: [yuv4mpeg] 720x400 => 720x400 Planar YV12
    VO: Description: yuv4mpeg output for mjpegtools
    VO: Author: Robert Kesterson <robertk@robertk.com>
    *** [vo] Allocating (slices) mp_image_t, 720x400x12bpp YUV planar, 432000 bytes
    Uninit audio filters...
    [libaf] Removing filter dummy
    uninit audio: mp3lib
    uninit video: ffmpeg
    wait, encoding to mp2 audio with mp2enc...
    INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
    INFO: Encoding with psychoacoustic model 2 is finished
    INFO: The MPEG encoded output file name is "/Users/admin/Desktop/49/49.avi.ff.mpa"
    INFO: [mplex] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
    **ERROR: [mplex] Unable to open file /Users/admin/Desktop/49/49.avi.ff.mpv for reading.
    Its on a new mac pro. With my Imac i don't have any problems. What i'm i doing wrong?
    Thanks and greets.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Originally Posted by Kiona
    Process info;
    The encoder engine, mpeg2enc, seems broken (malformed), hence no video encoding is taking place. Try downloading and installing it again. If it still fails, try this copy instead; it seems to have solved it for some users with continuous mpeg2enc problems.
    Nov 2005
    Belgium
    Thanks, I tried for many times to install de mpeg2codec. I'm gonna try the copy you send me the link of. I'll let you know if it worked.
    Nov 2005
    Belgium
    Hello,
    already a while ago.
    I tried it and downloaded your link, but still the same problem. Some other suggestions what i'm doing Wrong?
    Aug 2005
    Palo Alto, California USA
    Could you perhaps describe in agonizing detail precisely what steps you are following?
    Nov 2005
    Belgium
    Summary
    Source format is .avi
    target format: DVD mpeg2enc
    Video
    autosize: DVD
    Filters
    Load subs: .srt file
    Options
    Decode with mplayer
    These are the steps i take to encode.
    Aug 2005
    I was referring to your installation of mpeg2enc. Isn't that the problem?
    Nov 2005
    Belgium
    Oops sorry,
    I'm going to:
    Install binaries
    select mpeg2enc -> locate (on my desktop)
    enter my password
    then install
    that's it.
    Aug 2005
    Missing from the steps you listed (I asked for excruciating detail, so I am assuming that those steps are truly all of the steps you followed) is an unzipping of the mpeg2enc archive. A zipfile is not a binary; it is a compressed archive. You must unzip first, and the unzipped result is what you will then point to. So, if you have been persistently omitting this important step, that would explain why you have had trouble all along.
    Nov 2005
    Belgium
    I'm sorry, yes i unzipped the file. That go's automaticly.
    I'm gonna try it again but then the hard way.
