I know this is probably the stupidest question ever asked here, but i was just curious for personal reasons, instead of having to read the disc onto a computer, is it possible to capture from a MiniDVD camcorder, via firewire, very much like a MiniDV camcorder?
Thanks.
Does it have a 1394 (FireWire) output? If not, no. AFAIK, a Mini-DVD camcorder records to MPEG-2 format and that's the only format available.
With most DV camcorders using tape, the camera converts the video to DV format, then records that on the DV tape. When you transfer that DV file to the computer, it's just a direct data transfer from the tape, not really capturing. -
i see then, therfore, is it possible to transfer the data from the disc onto a computer?
probably easiest to put the cam dvd in the computer and copy the files off that way. otherwise the cam most likely has a usb connection you could use to do a file copy.
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Cannot capture - DV Camcorder to PC
By kev35 in forum Capturing and VCRReplies: 9Last Post: 8th Sep 2008, 09:43 -
Capture from DV Camcorder
By quxote in forum Capturing and VCRReplies: 2Last Post: 16th Jun 2008, 22:41 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Using files from a MiniDVD Camcorder
By djc38510 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 09:57
