    Jul 2008
    I purchased a GarageBand jampack DVD but would rather use the loops in a PC app. One of the few proggies that can convert the AIFs is Audacity. But there are quite a few files so a batch converter would be useful. I've searched everywhere but cannot find a solution.
    Anyone know of a batch converter that'll work on these files?
    tnx - GA
    Jul 2008
    Forgot to include the word 'free' for solutions. I did find commercial options, but I only need this one time.
    Tnx, - GA
  3. Member Soopafresh's Avatar
    Jan 2004
    Try RazorLame . I think it should work with AIFF input files.
  4. You can batch convert with foobar2000
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    There's also dbPowerAmp, though I don't know if you'd have to visit their Codec Central and download support for AIFF files, offhand. All you'd have to do is select all the files in Explorer and select the convert option from the right-click menu.
    Jul 2008
    Thanks all - will try the above suggestions tonight!
    GA
    Jul 2008
    There's a good reason foobar2000 has a 9.9 rating. It's free and works perfectly.
    GA
