Hi,
I have a quite strange error when it comes to subtitles on a DVD I have burned. This is what happens:
I rip the movie to my hdd to edit the subtitles in dvdsubedit. Usually I alter the height of them, and remove hard-of-hearing subs if there are any. Then I burn them to a blank dvd and watch them on my TV by using the PS3 as a DVD player.
But in a few movies, some subtitles are not rendered properly. Instead of the subtitle being displayed, the whole screen goes pink that second it is supposed to be displayed. This only happens with a few subtitles in these movies, not all.
When I play back the DVD on my PC with PowerDVD however, the error is no longer present.
I was wondering if anyone knows what this might be caused by?
You should probably try to use the latest DVDSubEdit version:
http://download.videohelp.com/DVDSubEdit/Downloads/DVDSubEdit1.4107.zip
and see if the problem persists... If it does, I might have to take a look at your examples...
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
Pink hue on TV
By uniks in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2011, 07:00 -
Laptop Pink screen of doom! Please help!
By hellfire45 in forum ComputerReplies: 3Last Post: 25th Dec 2010, 13:24 -
Subtitle problem that fills screen with pink
By oldjoe911 in forum SubtitleReplies: 2Last Post: 27th Oct 2008, 14:54 -
YpbPr on Hdtv only shows pink screen.
By tiagirl in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2008, 13:18 -
Subs cover-up bottom of screen
By ProudAnselmo in forum SubtitleReplies: 3Last Post: 10th Jun 2007, 02:13
