	What tmpgenc version ? You might be able to import mp4 if you can play the mp4 using wmp. If you can't then install haali media splitter and ffdshow.
 But you can also convert using super:
 What video and audio codec are you using? I guess it would be easiest to use divx/xvid with mp3. Or huffyuv video and wav audio.
	tmpgenc plus 2.5
 i set the output to avi/mpeg4/mp3, rendered file optimizer to divx
	the way i understand all this is
 avi is a file 'wrapper' / extension for holding a video stream & a audio stream
 MP4 is also a wrapper/extension format for holding/muxing video & audio streams
 mpeg4 is the basic codec, dvix and xvid are sub-variations of this codec
 an MP4 file is NOT an avi file
 my_vid.avi is NOT the same as my_vid.mp4
 although both can use mpeg4 codecs and mp3 audio
 and the only thing i ever used tmpgenc for was to make mpeg1 or mpeg2 files for burning to vcd and dvd,
 i have never used it to make AVI files
 for that I usually use Super
  YouTube FLV to MP4 with SUPER?By terrypin in forum Video ConversionReplies: 0Last Post: 28th Dec 2010, 07:06
  What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05
  Using super mp4 to DV(avi) only pal ?By doggyjumper in forum Video ConversionReplies: 4Last Post: 13th Sep 2008, 19:48
  trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 19:45
  using SUPER to convert a DVD to MP4By snafubaby in forum Video ConversionReplies: 1Last Post: 8th Aug 2007, 16:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
