Hi guys (and ladies), I've searched through the forums a bit but only to get more confused. I'm looking for an all in one utility that will let me backup/copy both DVD's that I've authored using Premier Elements as well as some DVD's that I have that have started to get scratched up and being that I lend them out a fair bit they will continue to get scratched, I'd rather keep the original on my shelf in the jewl case and lend the backup, (I'm a college basketball coach, so a lot of these are DVD's that I've bought outlining fundementals, offenses etc.) but the ones that I haven't authored tend to be copy-protected.
I used to have DVDxcopy which worked great, but don't have it any longer, are there any "new" alternatives that are as easy and simple to use, essentially one click? I don't want to have to worry about any options and really don't care about being able to change any options etc. So I welcome all suggestions for a newbie.
Secondly what would you suggest for software to allow me to convert my DVD to an ipod compatable format (as I'd like to take some of these DVD's on the road with me and watch them on my Ipod video).
Thanks again and sorry for the redundant post, I just couldn't find a definative answer in the existing threads.
Cheers,
Matt
Sorry I forgot to mention two other things, one it would be great if it automatically sized the file to fit on a single DVD (or if available to me a DL DVD) and secondly it doesn't have to be free-ware, I don't mind paying for something that works, I just bought Corel DVDCopy 6 yesterday and it won't do what I want unfortunately.
https://www.videohelp.com/tools/DVD_ShrinkAre any of these programs one stop utilities that will backup any DVD to a blank DVD and automatically re-size it to the size I choose without having to use more than one program?
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 20:35 -
Extremely easy backup solution.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 19th Nov 2008, 11:14 -
Newbie making good progress with 1080i content needing expert advise
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Jun 2008, 12:01 -
Free and easy drive backup/restore software
By pcspeak in forum ComputerReplies: 4Last Post: 8th Jun 2008, 00:10 -
screenshots for PAL DVDs (VOB files)--need frame info + step feature
By ezu0526 in forum Software PlayingReplies: 0Last Post: 8th Jun 2007, 16:06
