I don't have a HD-DVD or Blu-Ray computer drive and was wondering if there was any way to easily get the audio from a commentary ripped so I can play it on my iPod.
Thanks,
James
I doubt that you will find any easy tool for this (yet). But I would rip the hddvd/bluray using ANyDVD. Then try eac3to and open the evo(hd-dvd) or mt2s(blu-ray) file and save as wav. See http://forum.doom9.org/forumdisplay.php?f=9
Any way? Yes.
Easy way? No.
Without buying a BluRay or HD DVD drive, you'll have to find an alternate means of getting someone else's rips to your PC at which you could use eac3to to try to get the audio file. Note that high def audio probably will have to be re-encoded to something your iPod can play.
Best CD ripping
By magillagorilla in forum DVD RippingReplies: 36Last Post: 14th Sep 2015, 22:53 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
New, have some ripping Q's
By RooD in forum Blu-ray RippingReplies: 3Last Post: 10th Dec 2010, 10:57 -
can you rip blurays and then remove audio commentaries without reencoding?
By krohm in forum Blu-ray RippingReplies: 2Last Post: 1st Mar 2010, 08:54 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
