I have lots of family videos in SHVS format...thinking about using the Canopus ADVC 110 to convert and then suck all of the info into an iMac and use iMovie to edit/create new movies. This is a "hobby" project for my wife and I know it will take lots of time. Am I going down the right path? What haven't I considered? Is there better hardware/software for accomplishing this task? Appreciate insights from anyone who has "been there, done that!"
Using ADVC to transfer your SVHS tapes to your PC (Mac, whatever), it is considered the best method quality wise. It needs plenty of HDD space, a good encoder so to convert AVI to mpeg 2 (or whatever) and probably some filtering, that you can add by using additional programs.
All that needs time, some effort to learn the curve of doing it and probably you won't get it right from your first attempt.
Most people simply buy a standalone DVD Recorder to do this job. You loose a 10% of the so called "perfect result" that way, but you gain time. Much time.
The choice is yours.La Linea by Osvaldo Cavandoli
The ADVC110 needs a good signal - you'll need a TBC.
The levels on my S-VHS camcorder tapes turned out to be wrong, so I needed a proc-amp too.
You will probably need some denoising somewhere - S-VHS isn't perfect, and the chroma is no better than VHS.
Cheers,
David. -
That's not good enough for me. I want to remove VHS/S-VHS errors, not keep them forever. This includes grain, chroma noise, timing/sync distortions, etc.Originally Posted by hech54
A DVD recorder that filters tape flaws is often a better route than the DV conversion method.Want my help? Ask here! (not via PM!)
how to replace a JVC SVHS video head? lordsmurf?
By Blackout in forum Capturing and VCRReplies: 4Last Post: 30th Mar 2011, 17:02 -
need some advice on some svhs and video cassette recorders
By gnrforever in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 16:57 -
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Dec 2009, 16:00 -
Heelp to restore this SVHS tape (a frame of the video attached)
By SorenFRB in forum RestorationReplies: 32Last Post: 15th Dec 2009, 10:19 -
Opinions on JVC SVHS active Video Calibration feature
By robjv1 in forum RestorationReplies: 15Last Post: 18th Mar 2009, 01:37
