Bought a Tevion DVD3602UKT DVD player this morning and I would like to make it region free. I've tried searching on Google, but haven't found anything relating to this player and have tried a few hacks for other Tevion players, but again nothing.
Every player cannot be hacked. You may not be able to find a hack because one may not exist. This is why you need to do research BEFORE you buy to be sure that your player can be hacked. And also note that some players that do have working hacks will have hardware changes by the manufacturer that break those hacks. If you bought this player specifically to make it region free, re-read my first sentence and take it back.
Happily, you can make the Tevion DVD3602UKT HDMI DVD player region free; this worked for me:
Open Tray
Press 9999 on the remote
Wait 2 seconds
Press 9 for region free
Close Tray.
More information about it here: http://boards.ie/vbulletin/showthread.php?t=2055365693 -
mfraser - You have no idea how very lucky you are. Maybe 1 out of every 100 posts like yours has a happy ending where someone will post a working hack that can't be found on a Google search. My advice to be sure you can hack it prior to buying is still sound, but you got very very lucky on this one.
Tevion TSDVD1300 Region Hack?
By cutthroat_jake in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Apr 2011, 10:54 -
Cambridge Audio DVD53RW DVD Player - Region Hack Code Required
By Teac23 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2008, 11:43 -
Region Hack needed - Tevion TDVD08
By PocketRocket in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Jan 2008, 18:39 -
Region Hack - Tevion TDVD08
By Giosomm in forum DVD & Blu-ray PlayersReplies: 9Last Post: 29th Aug 2007, 08:32 -
Region hack required for LG RH188S
By keith_brooks in forum DVD & Blu-ray RecordersReplies: 7Last Post: 25th Jul 2007, 05:42
