Results 1 to 11 of 11
  1. Has this happened to anyone? I also get the occassional blue screen noting pciidex.sys as the source of my problem but I have not found any useful information on how I can fix it.
    Is it a "DRIVER_IRQL_NOT_LESS_OR_EQUAL" blue-screen error message? Then it's usually a memory problem.
    Check http://aumha.org/a/stop.htm
  3. Yes. I actually replaced the memory with an old set of mine and it still happens.
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Seems like the last time I looked up the "DRIVER_IRQL_NOT_LESS_OR_EQUAL" error, it was typically driver related. May be try updating or reinstalling the motherboard drivers. Aside from that, you would likely have better luck looking up the actual error codes from the BSOD.
    Google is your Friend
  5. I'm not sure what to do at this point because I've looked online and there is no clear cut method for fixing this problem. I've reseated all my peripherals, changed the memory, updated the motherboard drivers, etc. For the record the computer doesn't always give me the BSOD. Sometimes it just restarts without any message or a different one involving a different .sys file.
    Nov 2005
    Ozstraya
    Have you looked at the minidumps that windows leaves after BSOD?
    Try this.
    How are your temps?
  7. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    IRQ conflict? You could check your MOBO owner's manual to see which slots are shared IRQ.
    That's what was causing my reboots when burning DVDs.
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
    Mar 2004
    Are you sucking too much juice out of your PSU? You don't have too many peripherals running on a 200 watt power supply? Does this ONLY happen when you attempt to burn a cd/dvd?
    -PB
  9. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    ahhhh... that's a good point too!
  10. Originally Posted by fredfillis
    Try this.
    How are your temps?
    Temps are fine. I downloaded the debugging tool but I have no idea how to use it to read the dumps.
    -PB
    I only wish that was the case but no it's nothing that simple and straightforward.
    Were you getting the same BSOD message I'm getting?
  11. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    it was a couple years ago, but the message did say something about "IRQ" something something "EQUAL" something something.
