Hi,
I demuxed a transported stream recording with ProjectX and got the DVB subtitles in son format (a lot of bmp images with the text and the son file).
Then I imported the son in DVDLab pro, and I see that that the program instead of showing the text that is in each bmp image shows the name of them. So the text of the first subtitles is "xxx1.bmp", the text of the second one, "xxxx2.bmp", etc.
I don't undestand it, where is the problem?, I thought there was no need of OCR if you have the son format because DVDLab pro could import the images. Well, I must have done a silly mistake or something.
Thank you in advance.
I edit to copy the first lines of the son file (there may be something wrong with the subtitle name, too long or I don't know):
st_format 2
Display_Start non_forced
TV_Type PAL
Tape_Type NON_DROP
Pixel_Area (0 575)
Directory M:\OSCAR\Nueva carpeta\PARA DVDLAB
SP_NUMBER START END FILE_NAME
Color (0 1 2 3)
Contrast (0 5 7 10)
Display_Area (000 474 720 518)
0000 00:02:03:12 00:02:04:24 manual - France 2 - 2008-07-15_1_st00000p1.bmp
0001 00:02:08:03 00:02:08:24 manual - France 2 - 2008-07-15_1_st00001p1.bmp
I hope this can help you..
DVD-Lab Pro with .sst or.son: How do I do it?
https://forum.videohelp.com/topic314109.htmlCoz knowledge is everything... left ;)
http://mriddler.blogspot.com
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 20:21 -
Overlapping subtitles on DVDLab Pro
By ikarishinji41 in forum Authoring (DVD)Replies: 3Last Post: 18th Jun 2010, 04:06 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09 -
Importing menu transitions from a DVD to another with DVDLab Pro
By lorix in forum Authoring (DVD)Replies: 7Last Post: 6th Nov 2008, 13:52 -
VCD to DVD with subtitles in DVDlab Pro - subs 'disappear'...
By nbarzgar in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2007, 11:16
