If your TV is 1080p, then no matter the input (1080i in this case), what's output by the television has to be 1080p.
Results 31 to 32 of 32
1080p/23.976 fps (aka 24p) can be carried over broadcast 1080i/29.97 fps with no loss.Originally Posted by stanjschr
Here is what your Bravia Image processor must do...
Straight 1080i/29.97 fps interlace video (e.g. news, sports, reality or TV variety shows) will be deinterlaced to 1080p/59.94 fps for display. If your HDTV displays at "120 Hz" then each frame is repeated twice.
Movies or TV drama shows are shot 1080p/23.976 fps and telecined to 1080i/29.97 fps. The Bravia processor first detects that the scene is a telecine (aka "Cinema") source and then applies inverse telecine to remove redundant fields leaving a 1080p/23.976 fps raw film rate. Then the Bravia processor repeats frames 3x 2x 3x 2x to display at 59.94 fps. If the HDTV is "120Hz", then the 1080p/23.976 frames are repeated 5x or interpolated to 119.88 Hz for display.
The Bravia processor is capable of switching from deinterlace to inverse telecine on the fly and also has modes to deal with broken telecine cadence. Deinterlace is also adaptive to the types of objects and motion in the image. Often weave, bob and single field deinterlace are being applied to different pixel blocks of the same frame.
This may help you understand the image processor's role for ultimate picture quality. It is more important that you get a top end processor (e.g. Pioneer Kuro or Samsung 750 or Sony XBR7) than 1080p. The Kuro @ 768p is fine for normal viewing distances. If you get a bargain generic processor and a 1080p display panel, that means you will be seeing deinterlace artifacts and cadence detection errors in sharp resolution.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
1080i to 1080p
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Jan 2011, 06:38 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
Convert .TS 1080i into .TS 1080p?
By Lanford in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2010, 03:03 -
media player 1080p vs 1080i
By mishtag in forum Media Center PC / MediaCentersReplies: 25Last Post: 12th May 2010, 00:25 -
1080I camcorder or a 1080P
By zapper130 in forum Newbie / General discussionsReplies: 9Last Post: 16th Jan 2009, 17:44
