Hey guys!
Having a bit of problem wit my PS3, I have it set up to connect to wireless router (Netgear Rangemax DG834PN) for PS Network etc, the problem is when downloading content from the PS store the connection seems to be lost, however I can turn the system on and it will connect straight away, when i get the problem of what seems to be no connection if I run the network connection test I can obtain an IP address and Internet connection but when connect to the PSN it fails!
I have tried setting up port forwarding but the problem is still occuring!
Any ideas or any one had similar problems?
It could be your NAT type. or it could be an error with your key. Try doing automatic setup if you haven't, or manually set everything if you've done automatic. Sometimes the wrong key will make it look as though it's connected, but it's not able to do anything. Also, try the browser to see if anything comes up.
Nothing can stop me now, 'cause I don't care anymore. -
When the test does complete I do get a type 2 NAT. I tried using the manual set up instead of the automatic but still getting the same problem, but to start with everything seemed ok, the connection test completed, downloads started but then it all stopped working again, When using theNet browser I seem to be able to access it without any problems.
Blu-Ray to MKV to Hardcoded Vid w/ Subs to MKV to PS3
By psionicsin in forum Newbie / General discussionsReplies: 19Last Post: 3rd Mar 2011, 06:07 -
Hope this is the right forum - PS3 connection to Sony LCD TV
By Iansky in forum DVD & Blu-ray PlayersReplies: 9Last Post: 4th Jan 2011, 13:11 -
ps3 media server and blurays *wired connection
By krohm in forum Media Center PC / MediaCentersReplies: 4Last Post: 26th May 2010, 19:18 -
Problems with PS3 Compatibility
By AjzRide in forum Blu-ray RippingReplies: 4Last Post: 30th Jul 2009, 08:32 -
How do you keep TVERSITY connection active for the xbox 360 and PS3?
By yoda313 in forum Media Center PC / MediaCentersReplies: 7Last Post: 4th Jul 2008, 18:56
