I am looking for a programm, that can , help me, to remove an audio from a video and change it to the audio I need instead. I know about VDub but than the video converts to avi and I need it to stay untached completley.
Many people do exactly what you want to do with virtualdub (virtualdubmod is probably the simplest for audio handling) all the time. As has been pointed out, if you use Direct Stream Copy mode then there is no re-encoding.
Read my blog here.
Hi all.
remyisme.
Is it a problem such as feeding in an mpeg and having the output in an avi wrapper? What are you going to play the new video with?
catching up...Can you recommend a good camcorder?
By gts101 in forum Newbie / General discussionsReplies: 9Last Post: 16th Nov 2010, 04:44 -
can you recommend good ripping software ?
By Bansaw in forum DVD RippingReplies: 2Last Post: 14th Sep 2010, 19:39 -
Can anyone recommend a good AVI editor?
By djdust in forum Newbie / General discussionsReplies: 48Last Post: 17th May 2010, 14:46 -
Recommend a good subtitler?
By Djard in forum SubtitleReplies: 6Last Post: 9th Nov 2009, 03:57 -
Recommend a budget DVR? (no hard drive necesary)
By bbowens in forum DVD & Blu-ray RecordersReplies: 6Last Post: 3rd Jul 2007, 11:34
