Hi,
is there a way to delete the hard of hearing subtitles from idx/sub files?
Thank you in advance.
Thank you for answering. I didn't ask the question well. I meant a way to remove those specif subtitles with text in brackets that are among the dialogue subtitles in the same subtitle stream
Hehe, oh. Yeah, I thought you wanted to remove an entire sub stream.
It can be done using DVDSubEdit, under certain conditions. You'll need the DVD IFO as a source. I was just testing opening just a SUP file, and it looks like it can be made to work that way also. Subtitles can be converted from IDX/SUB to SUP and back again instantly using SubtitleCreator. Here's a guide for the use of DVDSubEdit for that:
http://download.videohelp.com/DVDSubEdit/Guides/HearingImpaired/guide.htm
Since that isn't quite what you had in mind, it may not be very useful to you. It simply can't be done using IDX/SUB files as a source as you'll have to modify the image files which make up the SUB file itself. -
Thanks. I've just converted the idx/vob to sup with Subtitle Creator. That's an advance. But I can't find a way to open this sup in Subtitle Creator in the main window where you're supposed to remove the hard of hearing subtitles.
As I said (maybe not very clearly), you open the SUP file in DVDSubEdit. That's what the guide to which I linked is for.
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 05:23 -
Problem On Subtitle SUB/IDX format.
By ashkan_vpm2 in forum SubtitleReplies: 8Last Post: 6th Dec 2010, 00:22 -
How to make idx/sub subtitles
By GoldenDragon in forum SubtitleReplies: 5Last Post: 1st Sep 2010, 10:40 -
Add/remove sub idx to/from vob
By ystiang in forum SubtitleReplies: 6Last Post: 8th Jun 2010, 23:50 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
