Can anyone recommend a reliable, easy-to-use, preferably free method of converting the MOV files I sometimes get from a friend's digicam to a widely usable format please?
I am currently having some success experimenting with the conversion software SUPER from eRight at http://www.erightsoft.net/SupCk2.html
But sometimes the result fails to allow the audio track to be played. And I'm out of my depth with many of the options in SUPER anyway. Such as whether or not to enable 'MEncoder' or 'ffmpeg', and whether to leave the audio output set to MP2 (default) or MP3. So if there's a simpler, no-brainer method of getting MOV to MPEG2 or AVI then I'm keen to try it please.
Terry, East Grinstead, UK
I would try Xvid4PSP, which is a pretty strong converter. The original files are most likely mjpeg compressed in a quicktime (MOV) container. You may need to have either quicktime alternative or ffdshow to make sure you can get full playback for the converter.
Read my blog here.
Thanks, appreciate the fast reply, I'll try that.
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 15:31 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
A program taht's is realtively simple like TDA & MyDvd. but more Robust
By Denvers Dawgs in forum Authoring (DVD)Replies: 5Last Post: 24th Jun 2009, 10:35 -
How would I convert MOV to AVI?
By Hittz in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 00:39 -
convert MOV file?
By AlanHK in forum Video ConversionReplies: 3Last Post: 18th Sep 2008, 06:27
