Hi,
So I've long wanted to edit my videos from my JVC Everio HDD camcorder, only to be frustrated by the fact that my Mac won't acknowledge the file format (.MOD) that the videos are saved as. I finally come across ffmpegx and have my videos converted beautifully. However, the audio does not join in the conversion and I am left with mimes every time.
An amateur at best, I have no idea what to do to get it right. When I drop the .MOD files into ffmpegx, the summary shows that the original audio format is ac3. When I hit "encode", the video converts just fine. However, for some reason, the audio doesn't follow suit.
Help?
I don't have any .MOD files to experiment with, but I would try the following: -
- Rename .MOD to .MPG
- Open in MPEG Streamclip and re-save as a proper .mpeg
- Rename the MPEG Streamclip output from .mpeg to a more common .mpg suffix
- Convert with ffmpegX to the desired output format. If a mencoder preset doesn't work, try an ffmpeg preset.
Audio in my video doesn't work on all computers
By MattMedia in forum AudioReplies: 4Last Post: 26th Jan 2011, 11:40 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 18:57 -
Software that converts .AVI into PS3 compatible format
By dec60228 in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2008, 09:27 -
Womble doesn't recognise avi audio from my Samsung Digimax
By keveen in forum AudioReplies: 2Last Post: 26th Jul 2007, 17:24
