Hi, For a long time I was using ConvertxtoDVD to convert then burn my dvds. All of a sudden the sound started getting off track with the video on a few of my dvds. Then it got to where the sound is off and my 360 wont even read it, It will usually play halfway through then the 360 always "attempts to read media" which is really annoying and I don't wait long before stopping the movie. I tried another program and the dvd I burned worked with two episodes but then the same problem, it couldn't read the dvd. I have an ASUS dvd burner and use memorex dvds. Any help would be great. Thanks.
It sounds like a media problem so I would first try another brand of media.
Memorex is not horrible media, but it ain't great. Either try a different brand, as Baldrick suggests, or try slower-speed burns. With cheap media, you'll generally get more satisfactory results burning at a notch or two below the maximum rate printed on the package. So if you've got 16x media, burn it at 8x, and see if you get better results. Then go out and buy some Verbatim or Taiyo-Yuden media.
Ill get some different dvds and try that, I've been burning at 4x and I buy the 100 pack of memorex dvds. I used over half of those before having problems. I will buy a different brand in a few days and see if that helps. Thanks!
Read www.nomorecoasters.com before shopping
I suggest VERBATIM (made anywhere) or SONY (made in Taiwan) or TAIYO YUDEN (online)Want my help? Ask here! (not via PM!)
i just burned a dvd?
By just in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2008, 21:41 -
burned DVD can't be played
By linda.0p in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 13:18 -
Burned Dvd a little choppy?
By kerouacknew in forum MacReplies: 7Last Post: 1st May 2008, 02:43 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
Cant read DV burned to DVD-R
By kunfuzed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2007, 05:20
