Is there some software that will capture from a firewire/dv source (VHS source through a clamshell) straight to divx/mpeg-4?
I've been trying AVS CaptureWizard, but none of the options produce a usable AVI except a regular DV-AVI. Divx or MPG4 or MPG2 all look like the picture is out of sync, everything is skewed and low-res..
I'm trying to eliminate the capture/encode process, as I have a lot of VHS cartoons I just want to put on a hard drive and then store the VHS tapes in the attic.
-Matthew
On the fly encoding is pretty CPU intensive, so without knowing your system specs (you can fill them out in your profile) I can only guess no.
Capturing direct to DivX or Xvid is not advisible.
Your best bet is to get a stand alone DVD recorder and record direct to MPEG-2 DVD or you can buy a capture card for your computer that does the same thing ... it will capture direct to MPEG-2 DVD spec with the card doing all the work (like a DVD player but on a PCI card).
- John "FulciLives" coleman"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Hi. I'm an idiot.
After reading your posts, I realized I have a Hauppauge PCI TV/Capture card installed in the machine.. I hooked the VCR up to the inputs and am capturing now. So far, so good!
I always just capture to DV-AVI and encode to whatever I want from there in Vegas..
BTW, IMHO VHS is the absolutely worst, most horrible format ever invented. The only redeeming value is the tape case: it keeps my kids from destroying the video much better than DVDs.
-Matthew
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 20:32 -
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 11:11 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
Divx has subtitles and I want them permanently on an MPEG, but....
By darthvonpokemon in forum SubtitleReplies: 2Last Post: 14th Jun 2008, 11:45 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17
