  1. Member Soopafresh's Avatar
    Jan 2004
    Stumbled upon a new piece of software (in beta) called BadaBoom, which converts many different formats (including AVCHD) to h264 .MP4 . What's interesting about this product is that it uses the relatively new Nividia CUDA technology - moving the transcoding engine to the GPU rather than the CPU on traditional conversion utils.
    Did a short test with a 85MB AVCHD .MTS file, comparing the transcoding time between BadaBoom and my batch scripted vimeo converter https://forum.videohelp.com/images/guides/p1814962/avchd_convert__vimeo_v7.zip .
    Results:
    On an 8 core XP box, Nvidia 8600 card
    Output: 1280x720 2500k deinterlaced
    Badaboom: 13.6fps 5% CPU utilization
    avchd_convert__vimeo_v7: 16.5fps 44% CPU utilization
    On a machine with less cores, BadaBoom would show an even faster relative transcoding speed. Looks like there's potential there. I wish the BadaBoom output would be more than h264 MP4, however.
    You can check out the Beta yourself. You need to update your Nvidia drivers to a fairly new build, or look for a file named nvcuda.dll on your drive to ensure your drivers are already CUDA optimized. I used 177.89 for testing
    http://www.badaboomit.com/
    And I just bought an ati hd 4870 graphic card. . .
  3. more info & testing here, the guys at doom9 have been following this for a while , there was also a preview in Anandtech (link to that article can be found in the thread below)
    http://forum.doom9.org/showthread.php?t=136847
    It's a promising start, but if you turn down the x264 settings to make it equivalent, CPU encoding on most modern systems is still faster.
    Quality is not the greatest, but the final release version is supposed to support "Main" profile at least (instead of just "baseline")
    OK for 1st generation, let's hope they can improve on it
    Sep 2008
    Don't worry, ATI is also working on this.
    http://forum.cyberlink.com/forum/posts/list/3307.page
    You're ATI card will work with that software, if you want to try it out.
  5. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Oh wow ... very nice. I wish I could afford that bad boy
    - John "FulciLives" Coleman
