wel it seems that i fix one problem and another one apears.
in this case,, i have a dvd on my HD which i would like to stream via Tversity to my xbox360.
the dvd exists of 2 directory's
audio_ts
video_ts
as you can see in the screenshot,, mpc says it have 2 files,, audio and video..
and as you can see it have 6ch audio ac3,, which is not supported by xbox360 ,, and probably the reason why it won't let me play the file..
but since this is not a .mkv container its not allowing me to fix the file with "gotsent" ,, (which would make things much easyer)
so i would like to achive the effect of playing it on xbox360 without having to transcode the "video"
what could i do to make it play?
all ideas are welcome,, as i have been bussy like the whole day today to make it work and didn't get much luck really.
Results 1 to 15 of 15
Have you just tried join the main vob files to one vob and play ? Join using vobmerge or rip to one vob from the dvd using dvd shrink or dvd decrypter.
i am doint this right now,, hoop it wil have some results,, i used dvd shrink,, this time i selected the "directory comment" which says in description is 2ch audio.Originally Posted by Baldrick
wil try to rename the vob to mpg extension.. -
not working,,
it seems like this is not really going to work with these vob files,,
i am just so confused,, couse i think i have downloaded like 100 diffirent tools and they are all supposed to do something,, and i have no clue what they are anymore.. -
wel what is wrong with winavi 9,
i have just converted one .vob movie into .avi,, with its default encoder ZJmedia encoder mpeg4, it went pretty fast,, a movie of 2 hours was converted in less then 30 min and the quality drop is almost not noticable...it seems to me winavi is the only choice for encoding fast without losing much on quality, but after all every program which would re encode would take off some quality so nothing to be done about it. -
This forum is littered with the sad and sorry history of WinAVI. Every patch release rained down a flurry of complaints and questions about why it no longer worked, why it was out of sync, or why it wouldn't play in this player or that. Most of them came here looking for help because WinAVI support is non-existent, and ironically, mentioned us on their website as somewhere to ask for help. We of course obliged by telling people to uninstall it and get a real program instead.
I know WinAVI has a core of supporters who like it because it bright and colourful and easily pirated (cue indignant protests about having paid for the software), but history here has shown many of us that it is nothing more than a waste space on any HDD.
There are far better free alternatives that have proper support. Speed isn't everything (ask your girlfriend, if you have one), and speed rarely goes hand in hand with quality (again, your girlfriend can vouch for this).
IMO, WinAVI is unreliable, substandard, poorly supported, and sub-par when it comes to quality.
If you are happy with it, use it.
But don't ask if it is a good product to use, then get offended if someone tells you it isn't.Read my blog here.
wel some comments made me laugh, computers technology and having sex with your girlfriend is something very very diffirent and cannot be compared :P , i don't feel ofended but i feel like you are bashing winavi for not a really good reason, as in my case it proved to work ok.
you are probably right about winavi not having good support, wel i can't say anything about it couse i haven't had any problems yet.
i have tryed and downloaded many tools (mostly freeware) which haven't really done much except waste my hdd. while others like gotsent, vob2mpg are the only ones that actualy left a good impression on me.
DVD Backup/Streaming to Xbox360
By touchingthevoid in forum Video Streaming DownloadingReplies: 4Last Post: 26th Sep 2010, 22:38 -
Steam DVd folders from PC to Ps3/xbox360
By pcexpress911 in forum Media Center PC / MediaCentersReplies: 20Last Post: 13th Feb 2009, 04:10 -
Is there a way to keep netflix streamed movies?
By louthewiz in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2008, 07:38 -
PS3 XBOX360 whit not originl movie dvd
By MOPLASMA in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Sep 2007, 13:10 -
streamed videos to psp
By zinc in forum Portable VideoReplies: 0Last Post: 1st Aug 2007, 14:46
