I saw another poster who had the same problem who just posted but the post hadstuff in it that was way too advanced for me to figure out...
Very simply I copied the .vob's from this dvd to my hard drivea nd encoded to xvid using CBR mp3 and after a few minutes each encoded file has audio desync. Do i need to do some really complicated editing/conversion/etc to get these videos to sync? If so I won't bother with it...
Also if I need to use avisynth to do it...I have avisynth installed and looked through the help file but that just made my head spin! That program looks hella complicated to use. I searched and searched in the help file for a way to hardcode subtiltes using it and couldn't find anything so I ended up using AutoGK.
	Ah, no I did not do that with the current discs I'm trying to rip. Actually on some earlier discs I used the vob files and didn't get any audio desync but then again each vob file wasn't over about say 12 minutes so that's probably why I didn't see any audio desync with those discs time. OK so open the .ifo files...I'll try that. Thanks.Originally Posted by Baldrick
	Ok, this time I definitely used the IFO files and I still got audio desync. What can I do?
  Audio desync after a while on Mpeg TSBy Liss0 in forum Video ConversionReplies: 0Last Post: 14th Jul 2011, 07:05
  Audio desync problems when capturing with FrapsBy ecjezl in forum Capturing and VCRReplies: 4Last Post: 29th Jun 2011, 23:48
  BIggg audio desync help!By iamtrojan3 in forum AudioReplies: 1Last Post: 17th Jul 2009, 03:05
  PSPEnc converions having audio desync issuesBy godfist314 in forum Portable VideoReplies: 2Last Post: 13th Sep 2008, 10:45
  Getting audio desync problem when ripping with DVDFab Platinum 4By godfist314 in forum DVD RippingReplies: 2Last Post: 8th Jul 2008, 14:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
