Somebody took some movie from a party last weekend, but he has a PAL camcorder. Now because I live in Canada, I have to capture in Premiere that movie in AVI files, right ? But it will be in PAL format. So after capturing, what I have to do to convert in NTSC for transfering on a regular VCR ?
Thank you very much
PS : I have a DV500 plus card in my computer, and i use Premiere 6.01
thanks a lot![]()
in a very general sense you need to do the video and audio separately then re-mux them:
1) using VDub, load the PAL video and change the framerate to 23.97fps. also load the resize filter to get the horizontal lines down to either 480 or 240, then frameserve to TMPGEnc and encode the video portion to MPEG-2, using the "3:2 pulldown/no flag/no interlace" option.
2) using some wav editor (sonic foundry?), elongate the audio track/stream to match your new 23.97fps/29.97fps video stream.
3) re-mux the audio/video streams
Convert 29,976 (NTSC) to 25,000 (Pal) AVI
By volker028 in forum Video ConversionReplies: 5Last Post: 23rd Mar 2012, 02:00 -
Cant convert Pal .AVI to NTSC DVD in Avidemux
By Hittz in forum Video ConversionReplies: 6Last Post: 5th Nov 2009, 07:43 -
Can AutoGK convert PAL Region 3 dvd to NTSC .avi?
By bloomcounty in forum Video ConversionReplies: 14Last Post: 20th Nov 2008, 19:31 -
how to convert pal avi to ntsc avi ?
By mainone in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2008, 11:27 -
Best point at which to Convert?? (NTSC AVI to PAL DVD)
By junk in forum Video ConversionReplies: 3Last Post: 28th Jun 2007, 16:15
