Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 30 of 39
  1. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Hi all,
    I bought a new HDD for my system and did a fresh install of WinXP SP2, but now the XP doesn't recognize DVDRW discs on my Optiarc (Sony-NEC) AD-7170A DVD/CD burner... It reads pressed and burned CDs and DVDs with no problem, but can't read any DVDRWs.
    I've scoured through the net for workarounds and patches, but none of 'em have worked.
    I'm more than sure it has something to do with WinXP, but I can't figure it out: when I connect my old HDD back, everything works fine and I can read any type of disc (CD/CDR/CDRW/DVD/DVDR/DVDRW), so it's not a hardware issue.
    I've visually compared the drivers in the old HDD and the new HDD and they're the same generic versions that come with WinXP... I've also compared registry entries for the burner and they're the same as well.
    I'm out of ideas... Anyone care to chime in?
    Thanks in advance.
    Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
  2. you need to install whatever software you used before to write the rw's. they sound like packet written(drag & drop) dvds. usually some form of roxio, or nero package installs it.
  3. You must have SP1 on your older setup. That may be the key to work with your burner.
    Try a XP with SP1, then a SP2 upgrade.
  4. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    I have Nero7 installed... Didn't make a difference.
  5. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Nope, I'm running SP2 on the old HDD...
    And fighting the urge to upgrade to SP3: leave well enough alone.
  6. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Oh, one other observation: if I connect a read-only DVD-ROM drive (an old BTC drive) in place of the Optiarc, I can read all media, even the DVDRW that the Optiarc cannot read with the new HDD WinXP install.
    The conclusion would be that the new HDD XP install doesn't recognize the Optiarc burner as such and thus cannot read DVDRWs.... But why?
  7. But why? because Vista is on sale and you haven't bought it yet..
    Delete the Burner and let winz re-install it..
    Nero infotool will tell you loads about your drive
    DVDinfopro will tell you even more
    Not region coding rearing its ugly head, possibly??
    or the aspi layer.. try imgburn ..DVDDEcrypter to burn as well
    The electronic components of the power part adopted a lot of Rubycons.
  8. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Vista???
    No thanks.
    Tried that... No dice.
    DVD Info Pro recognizes the drive and the DVDRW disc... But thinks the disc is blank.
    Nope.
    Region coding has nothing to do with it: I'm just trying to read data from a DVDRW disc.
    Hmm.
    There's a possibility.
  9. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Are you using a 80 wire ide cable? If not try one and if you are buy a new one. 80 wire ide cables can fail. Most of newer ide dvd burners require using a 80 wire ide cable or the drives will not work correctly. What brand is that DVDRW disc that you're using? Some dvd burners are not capable of reading certain DVDRW media.
    Have you checked for a firmware upgrade for your drive? SONY no longer makes their own dvd burners, they have a collaboration with NEC to manufacture the drives for them. Check out the SONY or NEC forums at CdFreaks.com and do some research or join and post your question there. SONY & NEC are notorious for not providing firmware upgrades for their drives.
  10. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Yeah, I'm using a 80-conductor IDE cable.
    ALL the hardware and cables are the same, just a different HDD, and XP has a problem with the Optiarc drive... When I reconnect the original HDD, everything works just fine, no issues with the Optiarc whatsoever.
    There's gotta be something missing or wrong with the new XP install, but I have no idea what it is.
  11. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    or the aspi layer..
    Downloaded and installed the Adaptec ASPI drivers... Didn't make a difference unfortunately.
    The next step is to attach my older Pioneer DVD burner to the new XP install and see if there's a difference. *fingers crossed*
  12. imgburn will tell you what your drive is specs are. imgburn/tools/drive/capabilities.
    any chance the drive and the hdd are on the same ide cable?
  13. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    I'll try it out, but I'm not too optimistic at the moment.
    Nope. The Optiarc is all alone on the secondary IDE cable.
    The other thing that kills me is how did I get the existing (old HDD) XP setup to work? I don't recall having all these issues with the Optiarc then..... *head scratch*
  14. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    As I suggested buy a NEW 80 wire ide cable because it would determine where or not the drive is defective. Many have bought new ide dvd burners and have had similar problems as you then they buy a new 80 wire ide cable and the drive works correctly. Just my 2 cents! Two each's own!
  15. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Swapped out the 80-conductor cable with a new one... No change.
    Did make this interesting discovery: when I attached my older Pioneer burner, the new XP HDD install had no problems recognizing my DVDRW discs or any other disc for that matter... So that sort of points to some kind of incompatibility with the Optiarc burner and the new XP SP2 install... But what?
    That fact that the Optiarc burner works just fine with the old XP SP2 install says that there's nothing really wrong with the Optiarc burner... Or does it?
  16. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    IMHO it sounds like the drive is defective that it can't read the DVDRW disc correctly because you said your PIONEER drive had no problems recognizing the DVDRW discs. My suggestion to you is to return the defective drive and buy yourself a PIONEER 115D from the PIONEER website. I read at Cdfreaks.com that PIONEER's website is selling it for $34.99 and shipping is one cent! Or you can buy a PIONEER 116 from Newegg.com. The PIONEER drive is a much better than the SONY/NEC that you have. Remember SONY just slaps it's name on the drive even though it's a collaboration with using the NEC chipset. PIONEER also uses the NEC chipset but it's a better dvd burner!
    http://www.pioneerelectronics.com/PUSA/Products/BusinessProducts/Blu-rayDisc+DVDWriter...iters/DVR-115D
    As always just my 2 cents!
  17. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    But it doesn't explain why the Optiarc burner works perfectly fine with my old XP install... That inconsistency has me befuddled.
    I've had the Optiarc burner for over two years... Can't return it.
  18. It sounds like your new XP install does not recognise your drive as a burner. HAve you tried looking at the windows driver versions on both HDD's?
    It could possibly (10% chance) be a power issue.. New drive takes more power therefore leaving Burner marginal, able to read but not write?
    Boot up LIve LINUX CD and check burning ability with that?
    Stick SONY on end of cable, change to CS, or MASTER or SLAVE.
    FAiling all that re-install windows XP, check to see if it works?
    install sp1 ,check to see if it works?
    install sp2 ,check to see if it works??
    install sp3 ,check to see if it works???
    What does DVDinfopro say about your drive?
    IS it perhaps the media? sometimes its best to just throw dodgy media out the door
    NEC are good drives
  19. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    I did compare driver versions: both are the same for both installs... No surprise, since both installs used the same XP SP2 disc.
    Seems remote, but I'll take a look at the power consumption of both drives.
    Live Linux?
    I only have the XP SP2 install disc... And have reinstalled a half dozen times with similar results.
    Haven't tried that or Imgburn.
    NEC are good drives
    The TDK DVDRWs read fine with the old XP install, with the old Pioneer burner, and the even older BTC DVD-ROM drive... Hard to point the finger at the media with that evidence.
  20. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    if you've had that OPTIARC drive for 2 years it's probably just dying. i've had some made in japan maxell DVD-RW discs fail after 2 years because i used them over and over in my pioneeer dvd recorder. try buying some new ones. dvd burners are so cheap these days buy a new one. just my 2 cents!
  21. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Normally I'd agree, but it doesn't explain why it works perfectly with my old XP SP2 install.
    Not trying to be anal, but this problem is inexplicable.
    Yeah, they are cheap, but still, it's a last resort.
    One other thing: I checked with Microsoft's HCL (Hardware Compatibility List) and the Optiarc AD-7170A is on the list, for what it's worth.
  22. Blow out your upper and lower filters
    Re-install Nero with InCD
    Originally Posted by jagabo
  23. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Originally Posted by stiltman
    I checked that per Microsoft's recommendation: those filters don't exist in the registry for my install.
    I was hoping to avoid InCD, since I've read so many negative things about it... But it's worth a try.
    Thanks!
  24. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Installed Nero7 with InCD... No change at all.
    Yet another weird discovery:
    I removed the Optiarc burner from my main PC and attached it to my secondary PC and it works fine on that PC...
    So at this point , the Optiarc works everywhere EXCEPT with my new XP install.
  25. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Sounds like your new xp is
  26. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Yup.
    Guess I'll borrow an XP disc from work and try installing from that disc... Can't say I'm very optimistic about it.
  27. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    Gonna try a new tactic later today: I'm going to install XP on my new HDD using my old Pioneer burner and once that's done, I'll swap in the Optiarc burner.
    If memory serves, my last clean install used the Pioneer burner and I added the Optiarc as an upgrade...
    Hope this works, 'cause I'm plum out of ideas.
  28. Member
    Sep 2008
    Canada
    I've used the following method to repair similar optical drive problems. If it doesn't work, you want to check for a firmware update.
    Step 1: Start Registry Editor
    Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
    Step 2: Delete the UpperFilters registry entry
    1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
    2. Expand SYSTEM, and then expand CurrentControlSet.
    3. Expand Control, and then expand Class.
    4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
    5. In the right pane (topic area), click UpperFilters.
    Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
    6. On the Edit menu, click Delete.
    7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
    Are you sure you want to delete this value?
    The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
    Note Do not exit Registry Editor. You must have this program for the next step.
    Step 3: Delete the LowerFilters registry entry
    5. In the right pane (topic area), click LowerFilters.
    Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
    7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
    The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
    8. Exit Registry Editor.
    Step 4: Restart the computer
    If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
  29. Member bmwracer's Avatar
    Sep 2003
    Driver's Seat
    ^ Thanks, but I've looked into that already: there are no entries for the Upper and Lower Filters in the registry.
    And I've updated the firmware on the Optiarc twice already and I've still got the same problem.
  30. Member
    Sep 2008
    Canada
    Well that's odd.
    I've performed that fix about 20 times and those keys were always there.
