Does anyone have any home lighting suggestions? I am putting all new lighting in my living room and wanted to have plenty of light for my Canon 400D and Canon HV30. I am thinking of putting in pot(?) lighting in the ceiling, and maybe having a lot of lights on a few different switches so that I can have normal lighting most of the time and a ton of light when I am shooting. Maybe add a dimmer switch, too. Also, I have the Reveal light bulbs through out the house that supposedly have a wider color spectrum. They seem to work okay. Does anyone have any thoughts?
Thanks,
Adam
If you are shooting video, overhead lights aren't going to help that much, except for fill in. You still need ground level lighting, usually portable. A couple of diffused tripod mounted lights or a umbrella reflector or two would be my choice.
If you really want ceiling mounted lighting for video, consider a track light set up. They have the advantage of being adjustable and you can add lights as needed. -
depends on what you want to shoot in the living room. closeups in high def on the couch? a couple of rewudz's big lights on rollers maybe? or large lamp base track lighting with heavy duty wiring that you could install spot lamps into when needed might work.
Lighting problem
By samoyed in forum Newbie / General discussionsReplies: 5Last Post: 11th Mar 2009, 17:56 -
Lighting
By ProducerHarley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Feb 2009, 20:54 -
Lighting
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jan 2009, 19:17 -
Environment lighting issues
By paulosfilho in forum Capturing and VCRReplies: 1Last Post: 17th Mar 2008, 14:00 -
Which Lighting is Better?
By wan2no in forum Newbie / General discussionsReplies: 9Last Post: 13th Sep 2007, 22:14
