Whenever there's movement of the picture on a DVD,
lines appear where there should be clean blur:
This occurs when watching from the DVD itself, or a VOB ripped from it.
I've tried it on three different computers with the same results (with VLC).
Is there a name for this phenomenon, and some way to prevent it?
It is called interlacing. You should not see it on a TV because they are designed for viewing interlaced material. Even newer progressive TVs such as plasma and LCD have clever circuitry built into make it look clean on playback.
Computer monitors do not have this circuitry, so the effect is very visible. VLC does have different deinterlacing filters that you can try (video->Deinterlace). try each one until you find one you like. They aren't as good as dedicated hardware (i.e. your TV), but then your monitor wasn't designed for watching movies.Read my blog here.
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 11:23 -
why do mpegs play with green flashing lines obscuing the picture??
By cyberraga in forum Software PlayingReplies: 1Last Post: 13th Dec 2007, 15:57 -
Lines in picture, HDTV PCI Card
By dnbrvr in forum DVB / IPTVReplies: 1Last Post: 2nd Dec 2007, 10:58
